I would like to ask if there is any way for displaying value returned by TCP probe on the map, if the probe can compare the value returned after sending command why can’t it be simply displayed?
Not exactly sure what you are getting at but you can create a function to read a value and put that function on the appearance of any device. In the appearance tab many of the built in functions can be picked from a drop down box.
Lebowski
