Syncing off of NTP is just not reliable.
A good GPS timing solution can cost several throusand of dollars (and you may need something for both ends).
The method Mikrotik uses for NV2 is just about as good as you can get without a GPS sync clock.
Gps sync is there to reduce self interference and to allow reuse of the same frequency. This can’t be done with nv2. If you have enough free spectrum you don’t need gps sync.
