Does anyone know if there are any standard, open TDMA protocols in the works? The main problem today is that each vendor has a different version of this technology that is proprietary. So if you want to use TDMA on a wireless network, roaming clients using their own devices cannot connect. Also, as far as I know, there are no USB adapters from any hardware vendors that support any version of TDMA.
I’ve been hoping for a TDMA hardware vendor such as Mikrotik or Ubiquiti to get aggressive and open-source their TDMA technology to hopefully create a standard that the industry will latch onto. I’ve also been wondering if LTE-U will be something that will be widely available for use in non-cellular systems. I’m thinking this may be a good solution to wifi timing too as I believe this includes TDMA.
Mikrotik reps: what is your opinion or the company’s position on these issues? More specifically:
- Is Mikrotik considering open-sourcing TDMA technology? Or is it already?
- Is there a USB NV2 device available? If not is there any future plans for one?
- Is Mikrotik considering developing LTE-U technology?
- Is there some fundamental flaw in using TDMA for WiFi networks that I am missing?
In case you use Ubiquiti and Mikrotik equipment as I do, you may notice that I posted something similar on the UBNT forum:
http://community.ubnt.com/t5/Wireless-Networking/TDMA-Standard-for-WiFi/m-p/1282638#U1282638
