TE tunnel on multiple ospf areas
Hi.
I have some sites in an ospf area A1 an some in area A2.
Each site have a vpls tunnel to a router VC, where VC is in area backbone.
Now I need to create a TE from a site X (in area A1) to VC and from a site Y (in area A2) to the same router VC.
My problem is in the router VC: I can set only mpls-te-area=backbone, then TE tunnels does not go up.
If I extend A1 and A2 areas to VC, however I can only select A1 or A2 in mpls-te-area.
Have someone a clue to this issue?
Thanks.
