TE Tunnels not routing data
I have a small ISP network running OSPF as iGP. Our IP addresses for CPE are assigned from central Radius server and distributed via OSPF…
We have 3 links in our network that are different speeds and I want to use TE to load balance these better, as we are ECMP at the moment.
I have the TE tunnels set up but I’m struggling to route data over them automagically. If I add a static route then it goes over the tunnel but I need to be able to do this automatically.
Also, each RB has a loopback with a /32 assigned to it - should I set the tunnels up with these /32 addresses or use the IP addresses for the interfaces on the interconnecting links? Either way doesn’t seem to work…
Have been stuck on this for a while now.
Thanks,
Adyb
If you are using OSPF to redistribute your loopbacks, I would definetly use the /32 loop IP’s for the tunnels. Need to see your config regarding the TE tunnels though.
