I am trying to create some TE tunnels for traffic management, to be able to use all our backup links, I configured a manual path and it showed running, when i assigned dynamic as to the secondary path, it could not run. Then i tried various other route, and some showed running and some did not show. No matter what i do.
But I cant get the tunnel running if i choose, cspf, unless i specify path on some areas and some areas it would not just come up no matter what i try.
This one i did not understand, configure all tunnels with a path between loopback address ( use 0 for bandwidth to avoid bandwidth constrain )
OSPF and MPLS are working on this one, my main link is R1, R2, R3 to HQ
I want to route traffic to R1,R2,R5,R6, R3 to HQ using TE.
I have set, Loopback addresses on all Routers, and tried to create a path for TE, so the alternate route is taken, but does not work. I cannot ping the TE interfaces on each side, R1 and HQ. As they dont show running. Any idea on what could be issue here ?
