Hi there, I'm new to Mikrotik and am currently trying to set up hAP ac lite as a home router/AP. The connection is directly to the fiber modem (by Deutsche Telekom) in my apartment. I've tried to piece together information from several guides online, but likely missed something. The current symptom is that PPPoE connections seems to be established successfully, however "ping 8.8.8.8" (from the router terminal) times out every time. Currently on my second day of headbanging, and would very much appreciate any tips/suggestions.
The configuration looks like this:
[admin@MikroTik] > /export compact hide-sensitive
jan/02/1970 00:40:49 by RouterOS 6.44.1
software id = 3GNC-QS21
model = RB952Ui-5ac2nD
serial number = B87F0A975FED
add admin-mac=74:4D:28:9A:6A:80 auto-mac=no comment=defconf mtu=1500 name=bridge
set [ find default-name=ether1 ] advertise=100M-half,100M-full
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX disabled=no distance=indoors frequency=auto l2mtu=1598 mode=ap-bridge ssid=MikroTik-9A6A85 wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX disabled=no distance=indoors frequency=auto mode=ap-bridge ssid=MikroTik-9A6A84 wireless-protocol=802.11
/interface vlan
add interface=ether1 name=vlan7 use-service-tag=yes vlan-id=7
/interface pppoe-client
add add-default-route=yes allow=pap disabled=no interface=vlan7 max-mtu=1492 name=pppoe-out1 user=XXXXXXXXXXXXYYYYYYYYYYYYZZZZ@t-online.de
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=wlan2
/interface detect-internet
set detect-interface-list=LAN
add address=192.168.88.1/24 comment=defconf interface=ether2 network=192.168.88.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=ether1
set allow-remote-requests=yes servers=8.8.8.8
/ip dns static
add address=192.168.88.1 name=router.lan
add action=drop chain=input comment="defconf: drop all not coming from LAN" disabled=yes in-interface-list=!LAN
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat ipsec-policy=out,none out-interface=pppoe-out1
/system logging
add topics=debug
add topics=debug
add topics=info,pppoe
/tool mac-server
/tool mac-server mac-winbox
And here are the firewall entries:
[admin@MikroTik] > /ip firewall filter print
0 D ;;; special dummy rule to show fasttrack counters
chain=forward action=passthrough
1 ;;; defconf: accept established,related,untracked
chain=input action=accept connection-state=established,related,untracked
2 ;;; defconf: drop invalid
chain=input action=drop connection-state=invalid
3 ;;; defconf: accept ICMP
chain=input action=accept protocol=icmp
4 X ;;; defconf: drop all not coming from LAN
chain=input action=drop in-interface-list=!LAN
5 ;;; defconf: accept in ipsec policy
chain=forward action=accept ipsec-policy=in,ipsec
6 ;;; defconf: accept out ipsec policy
chain=forward action=accept ipsec-policy=out,ipsec
7 ;;; defconf: fasttrack
chain=forward action=fasttrack-connection connection-state=established,related
8 ;;; defconf: accept established,related, untracked
chain=forward action=accept connection-state=established,related,untracked
9 ;;; defconf: drop invalid
chain=forward action=drop connection-state=invalid
10 ;;; defconf: drop all from WAN not DSTNATed
chain=forward action=drop connection-state=new connection-nat-state=!dstnat in-interface-list=WAN
[admin@MikroTik] > /ip firewall nat print
0 chain=srcnat action=masquerade out-interface=pppoe-out1 ipsec-policy=out,none
