can i found mikrotik OS has Telephony packge at version over 3.2
i only found this packge in 2.7
if not can i export telephony packge from 2.7, to instaled ver 3.3 ??
no, you can’t. telephony is not supported in newer RouterOS versions.
Dear normis,
ok if i’m using mikrotik 2.7 or 2.9 intalled on PC and with regular fax modem motrola or conexant can i use mikrotik as pstn gateway ?
or i must have cards from Quicknet Technologies,
no, you can’t.
these cards were supported:
Quicknet LineJACK or PhoneJACK analog telephony cards
ISDN cards
Voicetronix OpenLine4 (was V4PCI) - 4 analog telephone lines cards
Zaptel Wildcard X100P IP telephony card - 1 analog telephone line
here is the manual:
http://www.mikrotik.com/documentation/manual_2.7/IP/Telephony.html
ok, if i get one of these cards u send, i can use now mikrotik as PSTN gateway?
is these cards for pc or roterboards
read the manual I gave you. this version is many years old, I can’t help you any further.
Thx normis,
why not a simple hardware with any asterisk and have your routeros up-to-date?
dtoffo, do u mean to try asterisk ?
does it work with regular fax modem ?
I’m NOT an asterisk expert, but I just googled around:
http://www.asterisk.org/applications/fax
Thx, dtoffo
