teletronic
i have base station mt routerboard 532 and have some clent on it which they using senao and they all work fine but if try connect teletronic radio it would work with can any body help out thanks
If you mean the teletronics radio, I had before some CPE from teltetronics which where based on Prism radio and they worked, they get associated but I had to set the 802.1x mode = PEAP-MSCHAPV2 hope that this would help .
Regards Durim
