Telnet hotspot's user authentication - how to use it?
Hi!
Regarding to description from 2.9 OS manual:
“The HTTP PAP method also makes it possible to authenticate by requesting the page
/login?username=username&password=password . In case you want to log in using telnet connection,
the exact HTTP request would look like that: GET
/login?username=username&password=password HTTP/1.0 (note that the request is
case-sensitive)”
I would like to use telnet option to authenticate user.
First of all I have established radio channel and IP address assigned. Then in my Win XP I run command:
telnet 10.4.6.126 80
(where 10.4.6.126 is IP address assigned to wlan1 MT’s wireless interface)
then I paste:
GET /login?username=username&password=password HTTP/1.0
Unfortunately it returns error:
"HTTP/1.0 503 unknown method
Connection: close
Content-Length: 119
Date: Sat, 21 Oct 2006 19:41:46 GMT
Expires: Thu, 01 Jan 1970 00:00:00 GMT
Error 503: unknown method
What do I make wrong that there appear such error?
Thanks for any advice.
Marek
Do you have login-by=http-pap,… enabled in the hotspot profile for that hotspot?
–Tom
login-by=http-pap is active of course
Users are successfully authenticated based website login/password but are not able to login via telnet service.
Marek
