After upgrading the Mikrotik OS to 3.10 and MacOS to 10.5.3 (i don’t know wchich one caused the change) the build in terminal is no longer working correctly. All output is in one line and unreadable. I tried to change some parameters in the MacOS X terminal but didn’t have success.
Has anyone solved this problem, or found parameters to change within Router OS?
TIA
