Hi.
I need your help.
I have a RB450 connected on the internet with public IP.
i can’t access it via telnet, WebUi, or Winbox via internet.
i want to know if I need a specific configuration, for manage my router from any place.
thank for your help.
Badaro
check the configuration in ‘/ip services’ and in ‘/ip firewall fitler’ maybe you have some rules and restrictions set up there.
thank you Janisk.
My router is far from 800km .
i’m in another country.
i can ping it. but can’t telnet it or access it with winbox.
i want to know if i need specific configuration to access it using internet.
because i add a public IP on the Wan port.
thank you for your help.
badaro
there can be a lot of things configured that will not allow you to connect to the router from WAN port. there can be something configured between them etc.
Hi.
I just start using Mikrotik.
I don’t know a lot of thing on it.
please help me.
I want to know if it is possible to manage my RB450 using a public Adress.
help please
regards.
badaro
Are you using the default firewall config? (hint what does /ip firewall filter export show?)
If so the input chain may be dropping traffic from the external interface.
BTW - Doing remote admin via telnet is a bad idea. You should be using ssh or an encrypted webfig session.
there is probably firewall on the public interface as others have said. you need somebody on the LAN side to add exception rules for your IP, or temporarily disable firewall until you connect.
