telnet
can i reach all command from telnet
ex: check hide ssid
:put [/interface wireless get 0 hide-ssid]
Its also visible in /interface wireless print.
name=“wlan2” mtu=1546 mac-address=00:15:6D:XX:XX:XX arp=enabled interface-type=Atheros AR5413 mode=ap-bridge
ssid=“MikroTik” frequency=5765 band=5ghz-5mhz scan-list=default antenna-mode=ant-a wds-mode=disabled
wds-default-bridge=none wds-ignore-ssid=no default-authentication=no default-forwarding=no default-ap-tx-limit=0
default-client-tx-limit=0 > HIDE-SSID=NO > security-profile=default compression=no
thx so all command can be reach
yes. even more: not all commands are accessible via WinBox. some are in Terminal only
not work
v4.10:
[admin@MikroTik] > :put [/interface wireless get 0 hide-ssid]
false
[admin@MikroTik] >
also, replace ‘0’ with necessary interface name
p.s. what do you mean by ‘check’? to inspect or to enable?.. maybe you need “/interface wireless set 0 hide-ssid=yes”? :slight_smile:
i want to check and un check to make hide-sside= false than to make true
then - yes,
/interface wireless set <interface> hide-ssid=yes/no
