I see in the manual that there is /tool graphing health
But cannot find it in my unit (ROS3.3/RB532A)
How can I activate the temp graph to monitor heat on my routers?
Yes good question.
Wanna know also.
me 2, is there any suggestions ?
I think temp monitor is only available on rb230, because is the only one rb that haves a temperature sensor.
No voltage or temp on RB532/RB532A/RB333/RB133C?
You can see voltage on RB333 only from console.
[xx@xx] > system health
[xx@xx] /system health> print
fan-mode: manual
use-fan: main
active-fan: main
voltage: 27.1
For graphing purposes you can use mrtg and this linux script, or the dude with the oid.
#!/bin/sh
SW=“/usr/bin/snmpwalk”
uADDR=“ip_address”
utmpDATA=$SW -v1 -Oqn -cpublic $uADDR 1.3.6.1.4.1.14988.1.1.3.8.0 | awk '{ print $2 }'
uDATA=echo -e "scale = 0" "\n$utmpDATA / 10" | bc -l
echo $uDATA
AFAIK temp is only for rb230 and the other models don´t have neither temp or voltage monitor.
hope this helps.
regards
Thanks for that.
Suggestion to MT to add this little gem into manual that only RB230 support it.
