Temperature on Routerboard 433
Hi to all,
I would like to monitor the temperature on the routerboard 433, is this possible and how?
Thank in advance.
Tritsaris Costas
Anybody know about this subject?
If you search the forums you will find that it has been discussed many times before, and is not possible.
there are no temperature sensors on routerboards
Yet… ?
at least 433AH has voltage sensor now
Use one of these to control power to an ethernet hub/switch connected to a spare MT ethernet port. When your MT ethernet port goes up/down, you know the temperature has met it’s threshold.
http://www.lowes.com/lowes/lkn?action=productDetail&productId=230878-74493-YCT87K1045&lpage=none
on pc (x86) board is possible connect a thermometer throw the com port, but all RB machines has non standard com ports (missing 5V) .
Thank you all for your ideas and replys.
