Per the subject line. Is it possible to stop the System Scheduler with one command (instead of disabling individual events) then start it up again?
Thanks.
Thanks.
No, this is not possible… but you could create a script that disables all your schedules at the same time.
Yah, that would work.
I’m just doing some testing, and need to keep the Scheduler from turning things off and on for a while. Thought I might be able to treat it like a “service” and just turn it off.
