Dear community,
I have found an old script mostly useful for hotspots.
I need someone to help modifying the script to show capsman registered clients, and not hotspot authenticated users.
Is that possible ?
:local content
:local logcontenttemp ""
:local logcontent ""
:local counter
:local v 0
:set logcontenttemp "You are logged into: $[/system identity get name]"
:set logcontent ("$logcontent" ."$logcontenttemp" ."\n")
:set logcontenttemp "############### System Health ###############"
:set logcontenttemp "Uptime: $[/system resource get uptime] d:h:m:s"
:set logcontent ("$logcontent" ."$logcontenttemp" ." | ")
:set logcontenttemp "CPU: $[/system resource get cpu-load]%"
:set logcontenttemp "RAM: $(([/system resource get total-memory]-[/system resource get free-memory])/1024)/$([/system resource get total-memory]/1024)M"
#voltage and temp readout not available on x86, check for this before trying
#to record otherwise script will halt unexpectedly
:if ([/system resource get architecture-name]="x86") do={
:set logcontenttemp "Voltage: NIL"
:set logcontenttemp "Temp: NIL"
} else={
:set logcontenttemp "Voltage: $[:pick [/system health get voltage] 0 2] v"
:set logcontenttemp "Temp: $[ /system health get temperature]c"
:set logcontenttemp "############# User Auth Details #############"
:foreach counter in=[/ip hotspot active find ] do={:set v ($v + 1)}
:set logcontenttemp "Users Connected: $v |"
:set v 0
:foreach counter in=[/ppp active find ] do={:set v ($v + 1)}
:set logcontenttemp ("$logcontenttemp" . " PPP online: $v")
/system note set note="$logcontent"
