terminating sessions: interface state changed
  1. Version number (if the issue is upgrade related, specify which version was installed before as well); : ROS 7.0beta2
  2. Router’s model; : RB4011iGS+
  3. Steps to reproduce the issue :
  4. Bridge a PPPOE client into a Huawei EchoLife EG8245H5 modem/ONT/GPON
  5. Wait for couple of minutes/hours, ether10 will flap/disconnect by itself
  6. Configuration export (use ‘/export hide-sensitive’ command);
# oct/17/2019 05:07:12 by RouterOS 7.0beta2
# model = RB4011iGS+
set [ find default-name=sfp-sfpplus1 ] auto-negotiation=no l2mtu=9014 mtu=\
    9014 name=NAS rx-flow-control=on tx-flow-control=on
set [ find default-name=ether1 ] auto-negotiation=no
set [ find default-name=ether2 ] advertise=1000M-full auto-negotiation=no
set [ find default-name=ether3 ] speed=100Mbps
set [ find default-name=ether4 ] speed=100Mbps
set [ find default-name=ether5 ] speed=100Mbps
set [ find default-name=ether6 ] speed=100Mbps
set [ find default-name=ether7 ] speed=100Mbps
set [ find default-name=ether8 ] speed=100Mbps
set [ find default-name=ether9 ] speed=100Mbps
set [ find default-name=ether10 ] auto-negotiation=no loop-protect=on mtu=\
    1492 poe-out=off rx-flow-control=auto tx-flow-control=auto
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether10 keepalive-timeout=5 \
    name=Biznet user=redacted
set 0 default-vlan-id=0
set 1 default-vlan-id=0
set 2 default-vlan-id=0
set 3 default-vlan-id=0
set 4 default-vlan-id=0
set 5 default-vlan-id=0
set 6 default-vlan-id=0
set 7 default-vlan-id=0
set 8 default-vlan-id=0
set 9 default-vlan-id=0
set 10 default-vlan-id=0
set 11 default-vlan-id=0
add name=dhcp_hotspot ranges=10.8.8.2-10.8.8.254
add name=dhcp_monster ranges=10.9.9.2-10.9.9.254
add name=dhcp_nas ranges=10.10.10.2-10.10.10.254
add add-arp=yes address-pool=dhcp_hotspot always-broadcast=yes disabled=no \
    interface=ether1 name=Hotspot
add add-arp=yes address-pool=dhcp_monster always-broadcast=yes disabled=no \
    interface=ether2 name=Monster
add add-arp=yes address-pool=dhcp_nas always-broadcast=yes disabled=no \
    interface=NAS name=NAS
/system logging action
set 1 disk-file-name=log
/interface bridge settings
set allow-fast-path=no
set enabled=yes
/ip settings
set tcp-syncookies=yes
add address=10.8.8.1/24 interface=ether1 network=10.8.8.0
add address=10.9.9.1/24 interface=ether2 network=10.9.9.0
add address=10.10.10.1/24 interface=NAS network=10.10.10.0
add address=10.8.8.0/24 dns-server=10.8.8.1 gateway=10.8.8.1
add address=10.9.9.0/24 dns-server=10.9.9.1 gateway=10.9.9.1
add address=10.10.10.0/24 dns-server=10.10.10.1 gateway=10.10.10.1
set allow-remote-requests=yes cache-size=4096KiB max-concurrent-queries=10000 \
    max-concurrent-tcp-sessions=20000 servers=\
    203.142.82.222,203.142.84.222,8.8.8.8,8.8.4.4
add action=fasttrack-connection chain=forward connection-state=\
    established,related
add action=accept chain=forward connection-state=established,related
/ip firewall mangle
add action=change-mss chain=forward comment="Normalize MTU for IndiHome" \
    new-mss=1472 out-interface=Biznet passthrough=yes protocol=tcp tcp-flags=\
    syn tcp-mss=1493-65535
add action=change-mss chain=forward in-interface=Biznet new-mss=1472 \
    passthrough=yes protocol=tcp tcp-flags=syn tcp-mss=1493-65535
add action=masquerade chain=srcnat out-interface=Biznet src-address=\
    10.8.8.0/24
    10.9.9.0/24
    10.8.8.0/24
    10.9.9.0/24
    10.10.10.0/24
add check-gateway=ping comment=NAS disabled=yes dst-address=10.10.10.0/24 \
    gateway=""
    gateway=""
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ip ssh
set allow-none-crypto=yes forwarding-enabled=remote
/ip torrent
set download-directory=/flash/rw/disk
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=ether1 type=internal
add interface=Biznet type=external
add interface=NAS type=internal
#error exporting /ipv6/route/rule
#error exporting /routing/policy/selection
/system clock
set time-zone-name=Asia/Jakarta
/system identity
set name=Sentinel
/system logging
add topics=pppoe
add topics=debug
/system ntp client
set enabled=yes
/system ntp server
set manycast=yes
/system ntp client servers
add address=211.233.40.78
add address=202.156.0.34
/system resource irq rps
set NAS disabled=no
  1. Any additional information that would help troubleshoot the issue (screenshots, debug logs, etc.).
What i have done on my side is changing the UTP Cat6 cable to brand new cable & connector, the ether10/port flapping changing from every 20 Minutes into hours.
From past testing, this issue also happened with 6.45.6 or 6.46beta55
I have S+RJ10 attached into SFP+ port, before my power adapter is only 24 V 1.5 Ampere, after changing the power Adapter into 24 V 2.5 Ampere, the ether10 link is stable, now the link is up for more than 1d 06:14:00.
But the uptime only achievable by using ROS 6.45.6, using ROS 7.0beta3 is stuck with mentioned port flapping above, even it’s on hours or minutes for port flapping to happened.
Still not stable in v7.0beta5!, causing PPPOE-Client to disconnecting frequently, especially in high traffic.
