Terraform Issue
I don’t know why MikroTik Team changed forum to this one, previous was better but ok, back to the case
For TF users I have a case:
Code looks like this
provider.tf:
terraform {
  required_providers {
    routeros = {
      source = "terraform-routeros/routeros"
provider "routeros" {
  hosturl  = "apis://10.255.253.1" # env ROS_HOSTURL or MIKROTIK_HOST
  username = "konrad"               # env ROS_USERNAME or MIKROTIK_USER
  password = "xxxx"              # env ROS_PASSWORD or MIKROTIK_PASSWORD
  insecure = true # env ROS_INSECURE or MIKROTIK_INSECURE
main.tf:
locals {
  dhcp = yamldecode(file("${path.module}/dhcp.yaml"))
resource "routeros_ip_dhcp_server_lease" "leases" {
  for_each = local.dhcp.dhcp.leases
  mac_address = each.value.mac
  address     = each.value.ip_address
  comment     = each.value.comment
  server      = each.value.server
  dhcp_option = each.value.dhcp_option
  lifecycle {
    create_before_destroy = false
dhcp.yaml:
dhcp:
  leases:
    eset-eth:
      mac: A8:60:B6:24:EC:61
      ip_address: 10.255.0.10
      comment: eset-eth
      server: MGMT_LAN
      dhcp_option: ""
Important here is dhcp-option which was “h-node” now it’s “” , nothing. For tf it’s null.
When I run plan I get
❯ tf plan
routeros_ip_dhcp_server_lease.leases["eset-eth"]: Refreshing state... [id=*3174]
Terraform used the selected providers to generate the following execution plan. Resource actions are indicated with the following symbols:
  ~ update in-place
Terraform will perform the following actions:
  # routeros_ip_dhcp_server_lease.leases["eset-eth"] will be updated in-place
  ~ resource "routeros_ip_dhcp_server_lease" "leases" {
      - dhcp_option  = "h-node" -> null
        id           = "*3174"
        # (11 unchanged attributes hidden)
Plan: 0 to add, 1 to change, 0 to destroy.
And after Apply
❯ tf apply
  ~ update in-place
        id           = "*3174"
Do you want to perform these actions?
  Terraform will perform the actions described above.
  Only 'yes' will be accepted to approve.
  Enter a value: yes
routeros_ip_dhcp_server_lease.leases["eset-eth"]: Modifying... [id=*3174]
routeros_ip_dhcp_server_lease.leases["eset-eth"]: Modifications complete after 0s [id=*3174]
Apply complete! Resources: 0 added, 1 changed, 0 destroyed.
and on MikroTik
[recover@rtpoz1] /ip service> /ip dhcp-server lease print detail  where address=10.255.0.10
Flags: X - disabled, R - radius, D - dynamic, B - blocked
 0   ;;; eset-eth
     address=10.255.0.10 mac-address=A8:60:B6:24:EC:61 address-lists="" server=MGMT_LAN dhcp-option=h-node status=waiting last-seen=never
as you see h-node is still there. What is the problem?
I will add log from TF_LOG=TRACE
2023-07-17T19:21:13.416+0200 [DEBUG] provider.terraform-provider-routeros_v1.13.0: response body: !re @r1 [{`.id` `*3174`} {`address` `10.255.0.10`} {`mac-address` `A8:60:B6:24:EC:61`} {`address-lists` ``} {`server` `MGMT_LAN`} {`dhcp-option` `h-node`} {`status` `waiting`} {`last-seen` `never`} {`radius` `false`} {`dynamic` `false`} {`blocked` `false`} {`disabled` `false`} {`comment` `eset-eth`}]
!done @r1 []: tf_req_id=9d52f245-1d8b-bab2-7c05-d33e7f7e6dcd tf_rpc=Configure @caller=github.com/terraform-routeros/terraform-provider-routeros/routeros/log.go:16 @module=routeros tf_provider_addr=terraform-routeros/routeros timestamp=2023-07-17T19:21:13.407+0200
2023-07-17T19:21:13.416+0200 [DEBUG] provider.terraform-provider-routeros_v1.13.0: request body:  /ip/dhcp-server/lease/set =mac-address=A8:60:B6:24:EC:61 =server=MGMT_LAN =address=10.255.0.10 =block-access=no =disabled=no =dhcp-option= =comment=eset-eth: tf_req_id=9d52f245-1d8b-bab2-7c05-d33e7f7e6dcd tf_rpc=Configure @caller=github.com/terraform-routeros/terraform-provider-routeros/routeros/log.go:16 @module=routeros tf_provider_addr=terraform-routeros/routeros timestamp=2023-07-17T19:21:13.407+0200
2023-07-17T19:21:13.416+0200 [DEBUG] provider.terraform-provider-routeros_v1.13.0: response body: !done @r2 []: tf_rpc=Configure @caller=github.com/terraform-routeros/terraform-provider-routeros/routeros/log.go:16 @module=routeros tf_provider_addr=terraform-routeros/routeros tf_req_id=9d52f245-1d8b-bab2-7c05-d33e7f7e6dcd timestamp=2023-07-17T19:21:13.411+0200
it seems that it takes correct body with dhcp-option: h-node and then sending empty dhcp-option and it receives done 200 but even so on MikroTik I see that nothing changed.
