Hello! I’ve bought 2 SXT HG5 AC (CLIENT) and an mANTBOX 15s (AP), this to connect 3 office building distant max 200mt each like a bridge, the office with AP have a very high floor that i can see the floor where are 2 client.
I’ve bought this AC product because i want max troughput because i need to transfer my file over lan and see the video surveillance and also surf on internet
I am very very unhappy the max troughtput reached… is possible that i’ve max 40mbit TX/RX both in TCP mode if i transfer from Office A to B and vice versa? The signal and distance are good, i don’t know why this AC device give me this bad speed
I’ve attached all image that can prove this situation.
Ps. i’ve tryed also 802.11 mode but troughput is horrible! like 10mbit TX/RX both in TCP mode! Nstream give a better but the best are in my case with NV2 mode.
First of all:
Thanks for your reply!!!
I’ve tryed every setting, Before in 802.11 and i’ve a very poor bw… Than i’ve switched in nstream/ nv2, in comparison nv2 goes better result than nstreme and i’ve select this.
The freq are the best unused that i’ve find with Freq.Usage tool (-104dbm). I’ve tryed another range that seems free from usage from 5340mhz but the signal downcrese from -56 to -61db… I’ve tryed with 40Mhz Channel and eC and Ce extension mode and give me the same result (a little bit 10mbit less respect 80Mhz eCeee extension).
I hope a new firmware with a new driver to manage correctly this 802.11ac protocol.
For now i advice all user to not buy 802.11ac product: is a waste of money
I’ve setted 10 km because is the min value that winbox accept (range goes from 10 to 200).
I’ve tested all value from 1 to 10ms… best are 3ms, but if i set auto i notice a little bit troughtput
TX power in .ac device seems to be broken, i can’t show anything on winbox!
i’ve checked all freq range according to datasheet (5150- 5700) and i’ve tryed an not authorized freq but same result.
No any other antenna in the 500m range… except the classic 2ghz ap
HT MCS in .ac device is not adjustable
Tx power is set to default, i’ve tryed to chenge in fixed rate and its max 30dbm (more winbox give me a popup that its too high) but no success, i can’t show any significat improvement
