Is there any program to create a network model and test mikrotik? Like Cisco packet tracer
GNS3 + Virtualbox
Was a presentation on MUM about this.
I mean the program for testing mikrotik scripts.
like “Packet tracer”
I want test my scripts before using in real network with real Mikrotik
Here is a demo for Mikrotik Router …
http://www.mikrotik.com/software.html#
It’s the same answer… GNS3 + VirtualBox.
You create a VM, configure it. If you need to, use GNS3 to create a topology around it (just like in Packet Tracer, except less fancier).
And then run your scripts, and observe their effect.
Ok. Thanks, will try.
