Test - Improving Prism card stability in RouterOS v2.9
The wireless patch that we made to fix the prism card disconnection issues doesn’t contain the features that are supported in v2.9, for example, WPA.
If anyone are interested to help us to find the best way to fix the Prism card issues so it could work with features that are designed for v2.9, then please send an email to support@mikrotik.com for more information.
Where is this wireless patch available from? I am using the latest code and getting the same error messages described on the boards. With my Prisim card and the older routerboards?
-Michael
this patch is already in the regular wireless package. If you have some problems then send the description with the support output file to support@mikrotik.com
