Test Link result
What am I doing wrong here. The only difference between the two stations is the RX sensitivity. Why is there a 4dB difference in theoretical signal level?
The RX sensitivity should be the same on both side, if you want to build a backbone network, you should use the same devices on both side, this is my advice
+1
