Test racks
Here are a couple photos from one of our test racks, here we test both software and hardware. The last image shows our wireless test chamber, where we tested the 802.11ac
Very nice Normis.
Looks good!
nice
Nice playground. I have not seen any mAP or other new devices in the rack…
Yes it stands out when you know.
2 Points to MikroTik for using Velcro strips instead of zip-ties!
Yes, I know that Velcro doesn’t work for outdoor installations, but zip-ties are a royal pain when used in indoor racks, especially those installed in dark corners.
Cut MikroTik some slack. After all, they just started producing rack-mounted devices, so they’re still getting the hang of these rack standards from the distant past of tube-based radio gear and telco installations.
I assume this is the firmware update test rack…
It looks like there’s a RB850 in the rack just above the serial port server. It’s in the bottom left of this picture -
Yes, it could be. The Ethernet connectors/LEDs are reversed compared to a 450G.
So it is not a myth :laughing:
Very nice and clean!
Where can I buy those 1u cable organisers on the side of the rack? They look handy.
Is there a contest to win this ? :smiley:
They should be very common… :unamused:
You could get them even from eBay.
Nice rack :slight_smile: .
And that is the first time ever I’ve said this with it having a technical meaning, and not the other kind of meaning… :laughing:
Thanks all for your help…
As you can see my search term’s aren’t yielding any results. http://www.ebay.co.uk/sch/i.html?_odkw=1u+cable+organiser&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.X1u+cable+tidy&_nkw=1u+cable+tidy&_sacat=0 What should I be searching for?
http://bit.ly/1q7WrBQ
