Testing adlist failed !
Hello, not completely newbie .. but not master in mk.
To test the adlist system, I created a network configuration with two virtual machines under virtualbox .
The first is a MikroTik router (version 7.17rc2 ) and the second is a freshly installed Ubuntu Desktop.
Current configuration:
The MikroTik router receives an IP address from my local network: 192.168.88.21.
The router distributes IP addresses on the 192.168.89.1-254 network.
The Ubuntu Desktop gets the IP address 192.168.89.254.
Ping between router and Internet: OK.
DNS resolution: OK (verified with ping www.nasa.com)
On Ubuntu :
ip a :
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host noprefixroute
2: enp0s3: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
    link/ether 08:00:27:3c:cb:05 brd ff:ff:ff:ff:ff:ff
    inet 192.168.89.254/24 brd 192.168.89.255 scope global dynamic noprefixroute enp0s3
       valid_lft 1489sec preferred_lft 1489sec
Add blocking lists (see attached configuration).
Test performed with the “Can You Block It? WEBSITE: https://canyoublockit.com.
Ads are not blocked :frowning:
I enclose the export of my configuration for further analysis. Thanks in advance for your help.
config-test10-12.rsc (2.42 KB)
I don’t see enabled setting “allow remote requests” in your router.
make sure Ubuntu clears the DNS cache it might have in the system, also clear router DNS cache
try also these sites: https://d3ward.github.io/toolz/adblock
https://adblock-tester.com
Thanks ! Much better with !
What a fool I am !
