testing hotspot remotely
Hi There
Is there anyway I can test a hotspot remotely from another location?
I.e. get the splash screen and check that site are working correctly.
So traffic flow will be: remote location > internet > RB with hotspot > internet
Theres a few ways to do it.
  1. If you are running x86, run hotspot on a bridge interface, create a kvm and put the lan NIC in the bridge then VNC to the KVM (I normally use Linux live iso)
  2. You can create an EOIP tunnel and tunnel from you mikrotik to the hotspot and bridge the interfaces
