Test test test test test
Nope, no ”solved” option configured…
@admin2 @krisjanis, Please install the ”Solved” plugin.
I like that concept of using the “Site Feedback” — since commentary gets missed in what started as “forum is down for upgrade” thread.
Like here…
Solved plugin added. You can try it out.
Solved ![]()
Icon in topic list seems kinda small same as for subscribe/unsubscribe. Should we also take a look a that?
Yes please
Now that we have colors… How about making
green in the Title.
Absolutely. It has stupid barely noticable color (these colors are everywhere now, what the…). Make it a little bigger and green, as suggested by @Amm0
If someone is interested, made this fix in my CSS code for appearance improvement.
Additionally added highlighting for solution post and added a frame to solution link in the first post.
https://forum.mikrotik.com/t/improved-visual-appearance-css-based/261947/
Has this plugin been removed? I used it before here, but I was not able to see the option to mark an answer as the solution on my latest topic.
No, the plugin is still active. Check now please. I changed the settings a bit.
Whatever you did fixed it. Thanks.
I was able to select the solution post.
