as you can see, to start with I’m just trying to give wide open access so I can allow any device to upload to the mk tftp, once I can achieve this I’ll lock things down further.
Any thoughts on why this might be throwing that error?
also, when I connect to this from the router, it instantly throws cpu usage to 100% and then after 3 or 4 minutes the router becomes non responsive and a hard boot is required to get things going again.
I have the same problems with upload to tftp on RB450 with ROS 3.23. (but on RB1000 with ROS 3.23no problem)
[rb450] ip tftp print detail
Flags: X - disabled
0 ip-addresses=10.0.0.0/8 req-filename=“” real-filename=“” allow=yes read-only=no hits=0
And then try upload file from 10.10.52.11 - I have many logs:
11:00:47 tftp,info tftpd incoming connection on 127.221.194.120
11:00:47 tftp,info from 0.64.114.140:0
11:00:47 tftp,error error reading data
and CPU usage up 100% then after 3 or 4 minutes the router becomes non responsive and a hard boot is required.
