I try to enable Radius for Hotsport, it’s can’t work with IP address 192.168.88.1, but it’s works with 127.0.0.1 (both HotSpot and Radius setup the same IP address)
is it correct? if it use 127.0.0.1 for ROS radius server, another ROS can’t use this address, I think the 192.168.88.1 is the right one, but it can’t work.
I have to try change the Radius incoming port as 1700, but it’s useless, What can I do for it?
Thanks in advance for your warming reply, Help.
The version of my devices is RB2011, and ROS is 6.15
