Hi there. After reading the all the foruns related with this issue, none worked for me.
I use a RB532 with 2 internet connectios. On ether1 i connect to the lan (10.0.1.1) on ether2 (192.168.1.2) i connect it to an adsl router A(192.168.1.1) and the ether3 (192.168.0.2) i connect it to another adsl router B (192.168.0.1)
I tried adding the gateways to 2:1 (repeating the gateway ips), but the traffic always goes out throw ether2. Ether3 is almost dead.
I tried this solution How to use Transparent Web Proxy with 2 Internet Connections
and the odd / even packet solution, but the damn gateway that reaches the internet is the adsl router A ip.
My configurations:
[admin@MikroTik] ip route> print
C - connect, S - static, r - rip, b - bgp, o - ospf
DST-ADDRESS PREF-SRC G GATEWAY DISTANCE INTERFACE
0 ADC 10.0.1.0/24 10.0.1.1 ether1
1 ADC 192.168.0.0/24 192.168.0.3 ether3
2 ADC 192.168.1.0/24 192.168.1.3 ether2
3 A S 0.0.0.0/0 r 192.168.1.1 ether2
4 A S 0.0.0.0/0 r 192.168.0.1 ether3
5 A S 0.0.0.0/0 r 192.168.1.1 ether2
[admin@MikroTik] ip firewall nat> print
0 X ;;; masquerade hotspot network
chain=srcnat src-address=10.0.1.0/24 action=masquerade
1 chain=srcnat connection-mark=odd action=src-nat to-addresses=192.168.1.1 to-ports=0-65535
2 chain=srcnat connection-mark=even action=src-nat to-addresses=192.168.0.1 to-ports=0-65535
[admin@MikroTik] > ip route print
0 chain=prerouting in-interface=ether1 src-address-list=odd
action=mark-connection new-connection-mark=odd passthrough=yes
1 chain=prerouting in-interface=ether1 src-address-list=odd
action=mark-routing new-routing-mark=odd passthrough=yes
2 chain=prerouting in-interface=ether1 src-address-list=even
action=mark-connection new-connection-mark=even passthrough=yes
3 chain=prerouting in-interface=ether1 src-address-list=even
action=mark-routing new-routing-mark=even passthrough=yes
4 chain=prerouting in-interface=ether1 connection-state=new nth=1,1,0
5 chain=prerouting in-interface=ether1 connection-mark=odd
action=add-src-to-address-list address-list=odd address-list-timeout=1d
6 chain=prerouting in-interface=ether1 connection-mark=odd
action=mark-routing new-routing-mark=odd passthrough=no
7 chain=prerouting in-interface=ether1 connection-state=new nth=1,1,1
8 chain=prerouting in-interface=ether1 connection-mark=even
action=add-src-to-address-list address-list=even address-list-timeout=1d
9 chain=prerouting in-interface=ether1 connection-mark=even
action=mark-routing new-routing-mark=even passthrough=no
I checked all the wiki info in RouterOS - RouterOS - MikroTik Documentation and nothing worked. The routers are regular adsl routers with dynamic public ip and a chosen local ip. I´m using hotspot too.
Any help would be apreciated.
