The command "tool mac-server remove 0 " does not work...
Hi all;
When I execute the “tool mac-server remove 0”, the following error message appears:
can not remove default entry
Although I have added another interface for the same purpose as “all”, but I cannot delete that entry!
Any ideas?
Just what it says - you can’t remove it. You can however disable it
