The connections number, isn't it?
Hai fren,
did you understand about this, and how to knows it work
/ip fi fi add chain=forw prot=tcp tcp-flags=syn connection-limit=11,32 acti=drop
Thanks your time for.
regards
Rule allows 10 TCP connection for each network user, 11 TCP connection will be dropped.
Thanks Friend
i understood
