the dude 3.6 backup and upgrade procedure
hi all,
i was able to move a dude server 3.6 from a windows 2003 x64 to windows 2008 r2 copying the data folder.
now i’m starting to test dude 4.3b3 upgrade. then after install the .exe it i was able to view the .dat db file converting to .db. but when i start the client and try to connect to the server i can’t login anymore with my previous account.
then i strart from scratch. i have installed dude 3.6 copy the database, but this time the server won’t start(not open socket on 2210 etc) then i try to upgrade and suddenly i see open socket and connection to all my hosts monitored, but i still unable to enter on maps with client(error no connection could be made because the ta…)
there is a guide to upgrade/backup or i was wrong with something?
any help is welcome.
