The dude works fine for the most part. The only thing I cant do is backups. In the dude I click on export. It says exporting at the bottom left for about 2-3 minutes. Then the dude disconnects and then reconnects. It says Getting stuff at the bottom left. It dont matter what computer I do this too. I am afraid to upgrade because I had a big bug and had to downgrade. Well you cant downgrade because the databases are different. So I rebuilt my whole big network and I can’t do backups now. Thanks in advance.
I may have found the issue. I see the flash on the rb1000 is full. I bet that is causing the dude not to work properly. I am deleting anything I dont need and I will try a new backup.
