Hi i am fairly new to the dude, i setup an wisp and now i want my dude to send an sms to me, i have read up on email2sms and tried vodacoms service but does not look like it is working, i saw an post where they used “blat” to send out the email, but that aint working aswell, can somebody recommend an service that works?
Where do you set in the dude to send out an email?
My dude server is running on an pc.
*Goto Nottifications
*Open Email
*General TAB
*Setup email server address
*Put in the cell phones email address in the to field (normally something like 5551231234@txt.att.net)
*You need an SMTP server that allows relay
*Advanced TAB
*I check only down → up, up → down
I fully agree with ste. We use email notifications for most things but use SMS for email or internet connectivity issues. We use a third-party SMS tool (SMS-IT) and a dial-up modem on a PSTN line. A 3G modem would also be a good way but I think you would need a third-party app to send an SMS using it - or can The Dude do this natively?
the “execute” function runs a command on the dude server with the provided arguments and input in the given path, and returns the return code, program output and/or program error output.
executes program, returns array of three elements - return code, standard output, standard error. return code is -1 if error occurs. Only first parameter mandatory. First paramerter - command, second - parameters, third - path, forth - input string to pass to program, fifth - timeout in seconds (default 5.0)
Normis - is there any easy way to send sms from dude by other mikrotik device with usb modem on it?
Let’s say that i have a windows machine with dude o ip 10.0.2.2 and alix board with huawei modem on it with ip 10.0.2.3 (i am able to send sms from commandline of this mt).
