The Dude and Ubiquiti M5 monitoring...
I’m using The Dude version 3.6
Unfortunately I do not see the information Ubiquiti M5 Series devices.
It is easy to expand the dude to handle new devices, it is simply a matter of how good the SNMP software is on the device you want to monitor, or you could just ping stuff… You should read as much as you can before doing any type of auto discover. You will want to know what it will try to discover! Which is a lot!
The beta version is looking very good you should try it.
Nanostation 2 Label:
[Device.Type] [Device.Name]
[Device.FirstAddress] cpu:[oid("1.3.6.1.4.1.10002.1.1.1.4.2.1.3.1")]%
[oid("1.3.6.1.2.1.1.3.0")]
wireless clients: [wireless_clients()]
But the M5 is not required to access the information. :confused:
Either it uses different OIDs, or it doesn’t support those OIDs at all. You can run SNMP walk on this device, to see which information is available. Right click and choose SNMP walk
Thanks for that OID, CPU usage on my Nanostation 2 works!
I’ve noticed one problem though, when the device your monitoring/or link to it goes down, it won’t resume monitoring again when it comes back up, just stays blank.
