When I run the files thru TriIDNET it says its “XMill compressed XML.”
I would like to get access directly to the configuration data without having to export it to a XML file for read-only purposes. I would like to use The Dude as my main documentation system and be able to export information for my own purposes.
I am interested, too. This would allow me to import lots of device names, locations, configs, instructions and other helpful things into the config of a device/service.
I downloaded the suggested ODBC driver and can import all but one table into Access or Exel. Unfortunately the table I can’t get (objs) seems to be the one that links everything together. All the other tables just have values and ID references . Has anybody had any success with this?
XMill is a user-configurable, easy to use XML compressor. It separates structure, layout and data and distributes data elements into separate data streams. If you want to download odbc driver then try from: http://www.datadirect.com/products/odbc/index.html
