Hi all,
i’m using The Dude to monitoring my 2 remote offices. I’m monitoring all RouterOS services (ping, mikrotik, router, …). Is there any way how to use E-mail notification just fore one of them service, aka ping?
Thx, lin.
Hi all,
Thx, lin.
This is a little late and you may have found a solution already. In some instances, I Email based on regexp from the syslog. It’s one way I know immediately if someone is trying to access one of my routers.
Basically, comes through the log and I get an email. You set it up under Settings > Syslog tab.
If you used this method, you may be able to turn off the other notifications and pick up Dude’s log entry of “Service ping on is now”
