Hi.
Can somebody how to show a map o submap in full screen?
Can show map like slide transition?
is for show in 24" to monitor diferent sites and show all map with 2 secon delay automatic.
Tanks.
jose luis.
Hi.
Tanks.
jose luis.
Assuming you are running the dude on PC, you would have to write your own macro or script to switch between maps, you could do that maybe with something like tinytask. That would allow you to manually create a macro of your mouse clicks, just record clicking through every map one at a time and then save and run the macro in a loop. You can also compile a tinytask into an execute so you could add it to startup. Tinytask is from vtaskstudio.com
In the list of maps you can right click on a map and select “open separately”.
HTH,
Lebowski
Tanks. now is working!.
