I downloaded and uploaded tile and x86 to my 750GL and Grooves, npk doesnt get installed after rebooting
what am i doing wrong?
ggorbalan
http://wiki.mikrotik.com/wiki/Manual:The_Dude_v6/Installation
System requirements for server package
RouterOS:
v6.34rc13 or newerHardware:
MikroTik CCR series hardware
RouterOS x86 installations
RouterOS CHR environment
Note: Use of dude server package is not supported on other hardware.
ok. so that means that i need to buy a x86 licence in order to use the new dude ?
I only have grooves, 750gl’s, omnitiks … i dont have any CHR or CCR or X86
can i use any licence from my other gear to install a x86 in a VM ?
If 1mbit/s will be enough for your dude probes, than you can use CHR to run new dude for free.
Changes in v6.34rc45 build:
Fixed issues:
- Fixed server crash that some people where experiencing.
- CHR host upgrade fixed.
- DNS name resolving fixed in loader (will however work only after loader is upgraded to rc45)
- Added db vacuuming option
- Added progress indicator to import/export/vacuuming
Known issues:
- Device discovery tool does not work with Agents.
Regarding snmp issues with our devices, check if you have latest .mib file uploaded in dude server mibs dir.
why those changes are not added to RouterOS changelog?
http://download.mikrotik.com/dude-6.34rc45-tile.npk
gives
404 - Not Found
Vacuum! I am happy of that. Thank you very much for it. I will test as soon as I manage to have running both clients of 4b3 and 6rc on one windows station simultaneously.
Regarding my complaints about Dude not creating links correctly, please disregard. The latest rc builds work fine. I haven’t test the others yet.
Any update on this? I can force them to reconnect to ROS in Dude, but they disconnect some time after again.
I used this link:
http://download2.mikrotik.com/routeros/6.34rc45/dude-6.34rc45.npk
After install, dude server took about 1/2 hour to start.
From all the 6.34rc releases, I noticed that dude has difficulties connecting to objects that have Secure Mode checked.
I can confirm that unselecting Secure Mode fixed the ROS connection issues for me for now.
can you post a link for the dude server for the x86
thanks
ROS link mastering type was fixed some builds ago.
x86/CHR dude server package.
http://www.mikrotik.com/download/share/dude_6_34rc45.npk
Testing on a CCR1036 it lasts 10 minutes for dude to startup and load it’s data from an USB Stick.
How big is that dude db on usb flash? Have to get something similar and recheck.
jstump:
krisjanis:
Problem with link monitoring in cases where ROS is used as mastering type is know to us. Dev has bug report for it. hopefully it will get fixed soon.
Yeah, I mistook this issue for the Secure ROS connections issue. With Secure ROS checked, devices disconnect from Dude and don’t show links correctly. Turn off Secure and its fine.
Had an issue with settings not saving, only to realize the flash drive was full. Fixed.
Having lots of crashing issues now. Dude will crash and not start up until I get on the router and do a /dude pr and then it seems to start until next crash.
