the dude label, embedding a function inside quotes
I’m using an if statement to determine device type and then I want to print some oid info out like so
if(oid_raw(“0.0.0etc”)=1,
"station signal: oid(“1.2.3etc”) ",
“unknown”)
The problem is that the double quotes in oid() breaks the function. If I escape the quotes ie oid("1.2.3etc") then it just prints the quotes, doesn’t run the function.
any ideas?
note, I know how to do concatenate(“value1”,“value2”) but then it’s all one big line! If I could put a new line/ carriage return in the concatenate that would work too.
