No interfaces to choose from when setting properties of a Link to snmp, to view Rx/Tx speeds. Tried reinstall, different versions, vaccum-db. Nothing working.
Update:
Played around with program a little, and figured out that the interface setting (properties of link) reports the interface on the client end.
So…how do I add config/driver/etc for devices that aren’t automatically detected?
Have you configured the SNMP settings in your MikroTik? Make sure you’ve added a “community” and have the correct one selected under “trap community” in SNMP settings. I believe selecting a “trap version” is also necessary.
If you want to check Rx/Tx traffic between two devices (Ubiquiti NanoBeams for example), ensure you have configured the SNMP agent on both NanoBeams by selecting the “SNMP community” which was created in your MikroTik under “SNMP settings”.
