Hi All,
I have looked the whole forum, but haven’t found a right way to make THE DUDE warn when there is ping packet loss to certain device, or icmp timeouts.
Could you please give me a hand on this?
Best regards
Hi All,
Best regards
Perhaps I do not understand your question correctly, but the Dude default ping probe is designed to check router replies to ICMP, when ping is not possible (timeout), ping service is registered as down.
Cheers sergejs,
The problem with the ping service is that when we have ICMP loss around 20%, the dude does not warn us about this.
Yesterday i realized a equipment having more than 20% of ping timeouts, but it still green on my graph.
Any suggestions?
How come your dropping so much ICMP?
There was a ping probe that did 10 pings and calculated packet loss, check out the probe thread.
Here it is… thanks to Pablete
1st I have created a function:
Desc: number of replied pings from 10 ping requests (0-10)
Code:
if( array_element(ping(device_property(“FirstAddress”)) , 0)<0 , 0 , 1 ) +
2nd) I have created the probe
Type: function
Available: ping(device_property(“FirstAddress”)) >= 0
Error: “”
Value: packet_loss_test()*10
Unit: %
If you want finer values you can make an addition of 20 pings instead of 10 and change Value in the probe for
packet_loss_test()*5
but the probe will be more intrusive.
Sounds like it doesn’t work as planned
I have noticed that the Dude only performed two pings of the ten i wrote in the function. Options are:
Maybe you can add to it and fix it?
Cheers lebowski
This happens only during storms or hard rain days.
When this happens, i must know.
This is the reason that I’m looking for some way to figure out how many packets are being lost.
Is it a t1 line? Can you have them do intrusive testing when it is raining?
It’s a 15 mile radio link. I don’t see any problem having a full-time ping or any other intrusive test. What is your suggeston?
Ok so you know it breaks when it is raining because it is microwave… Disclaimer: Some of these things might not be accessible on your bridge.
Re-align the antennas and verify you are getting the most signal strength possible for the path. Calculate what your path loss should be compare your calculated value to the actual value, are they similar? if not try to determine why. Can you move one end of the link a few feet in any direction to improve line of sight?
Check your modulation/signal settings. If you can set the carrier to use 20mhz or 40mhz channels, use 20mhz.
Read up on which modulation/signal settings are most resistive to rain.
Only allow the bridge to run at a few speeds and include the ones that are resistive to rain)… These you will have to experiment with. I’d imagine that allowing the bridge to run at every speed is wasting time trying to negotiate a link at a speed that is not possible when it is raining. You might find that it runs well at certain slow speeds when it is raining. What speed does the link normally run at? Does it run at any speed in the rain?
Running 2.4ghz microwave in the rain over 15 miles is going to be tricky, consider adding a 900mhz redundant link?
As for intrusive testing what I was talking about is if someone else owns the circuit, have them test it. Since you own the link you can do all the testing you like…
I am making a lot of assumptions but instead of trying to determine how much traffic is being lost with a probe maybe you could improve the link.
I would probably build a probe that showed input error packets that would give you a good idea how the link normally performs vs when it is not. It is likely that error counts are going up quickly when it is raining.
Make a function that gives you the rate of difference for the input errors oid
Code: rate(oid(“1.3.6.1.2.1.2.2.1.14.12”)) ← that is for a Cisco T1 line on S0/0/0.
Make a probe that graphs errorrates000
Type: Function
Available: oid(“1.3.6.1.2.1.2.2.1.14.12”)
error: if(oid(“1.3.6.1.2.1.2.2.1.14.12”),“”,“Can’t read s0/0/0”)
Value: errorates000()
Unit: total
rate: none
Let us know how it goes and I HTH,
Lebowski
Good way is to keep an eye on this rain fade issue, I would suggest implementing some sort of Smokeping throughout your network to compliment the Dude as such, a program such as MultiPing.com for Windows PC is very cheap and has a great graphical representation and a weeks historical data you can check daily when you start your day. It can monitor hundreds of devices (ip’s) and send automated alerts.
Note, that now netwatch has some nice features to monitor different options,
https://help.mikrotik.com/docs/display/ROS/Netwatch#Netwatch-Type-specificoptions
I use the completely free tool with alerts at: https://axence.net/en/axence-nettools Help: https://axence.net/help/netTools/en/netTools.pdf
