The dude on RB760iGS
Hello
Cant get the dude to install on my RB760iGS.
I am not really sure of witch npk file i should use.
Hex S or RB760iGS is MMIPS, dude package should be for MMIPS and match the installed ROS version, e.g. if you have 6.40.8 installed: Dude 6.40.8 MMIPS
this guide can help
https://wiki.mikrotik.com/wiki/Manual:The_Dude_v6/The_Dude_server_on_hEX_RB750Gr3
I am surprised by this because how do you know which version of RouterOS is installed on the 760iGS?
For all three versions of RouterOS there is a separate version of Dude which can be found at this page: https://mikrotik.com/download and you have to search for MMIPS
And follow the instructions in the posting above (chechito).
Tank’s for the help.
i hade the wrong version now it is up and running.
Good catch, edited.
