the Dude, static element
Hello, can i make static element change colour when link between switch and static elements drops down. I want to make it visual when device changes status from WORKING/NOT WORKING. If yes, please explain how.
Thank you.
Have you tried using the speed feature of the link?
Yes, i tried. On link settings i fill in:
Mastering type → snmp
Interface → fast ethernet 0/1
and fill in Speed and Type. Wten in static element settings i choose label refresh interval. But when link drops down i want static element to change colour. I dont now how to do this. Please help.
If you go to settings, then the Map tab, you can edit the settings for the links. Try reversing the colors and and using the speed limit on the links. Everything will be backwards, but you should be able to make that work. If not then you could consider building a new function to use with the link settings.
