The dude stops responding after creating a empty function.
Hi
I was doing a change in one function and saved it (while the code field was empty)
It resulted on a imediate disconnection from the server :frowning:
When I tried to login again. I got an error in the client. Checked the event viewer and the Service states that: "The service did not respond to the start or control request in a timely fashion. "
It also happened when I for mistake pasted in the name of the Device the Field “Device.Name”
Both results were… reset configuration and start all over again.
Is there any type of Undo for these misfortune operations? Besides restore?
PS: using v2.0b10
thanks in advance
Ricardo
