The Dude - Unknown message
Hi all, my name is Marcio and I am using the Dude beta version (v18) and once in a while I see the label “unknown” displaying on some of my created objects (devices for example), does anybody know the reason of this label and What I should do to solve it!.
Basically, it happens when I install a new version of the Dude and then open a backup of my existing project (created with an older version). It does not happen all at once, it usually happens after a while where some of my devices display unknown and then cannot reconnect everafter.
Any clue about a fix for the unknown recovery?
Am I doing something wrong?
I appreciate any help ASAP
Tks
Marcio
it is probably becouse of some kind of bug in The Dude, either in some older
version or in current. It would really help if you could send your backup
file to support@mikrotik.com and describe what actions precisely you take to
get such results.
