How to open routerboards with the dude user?
Exemple:
User: glaubert
Pass: 12345678
i need open routerboard with same the dude user.. how to do it?
Exemple:
User: glaubert
Pass: 12345678
Hello, Glaubert!
What do you trying to accomplish?
As describing in the wiki, Dude v6 use ROS user database.
For example, in order to login into the Dude server, user should exist under ROS and should have dude policy enabled.
If you want to be able to login into ROS using user which is used for accessing Dude server, you should verify if it have required permissions. Then you will be able to login into ROS using Winbox/Webbox/SSH.
Thank you!
I’m using The Dude 3.6. How to do?
sorry for my bad english
Glaubert,
Dude, prior v6, were only windows server versions. In such case Dude contains its own user database and you can’t directly login into ROS using Dude user.
If you have a Dude version v3.6 with and multiple ROS devices you may:
