Dude v2.2 (February 27, 2007)
See http://www.mikrotik.com/dude/
Changelog:
v2.2:
*) fixed loading of maps, sometimes could stall
*) fixed too many digits after comma bug
*) other bug fixes
v2.1:
*) fixed panels
*) fixed builtin functions or, and, not
*) fixed some bugs in web server
*) other bug fixes
v2.0:
*) web server could not work
*) fixed import
*) panels sometimes could become unconfigurable
*) fixed memory leak with failing local connections
*) minor fixes
v2.0beta12:
*) fixed possible crash when discovering
*) service counts could be accounted incorrectly
*) fixed web interface link info bug
*) fixed problem with secure web interface
*) oid picker performs snmp walk as from server not client
*) snmpwalk could use incorrect snmp profile
*) other fixes
v2.0beta11:
*) non-integer number output, builtin round function
*) fixed rate function
*) bug fixes
v2.0beta10:
*) improved accuracy of network discovery
*) bug fixes and performance improvements
v2.0beta9:
*) many bug fixes
v2.0beta8:
*) tables have selectable columns
*) multiple dude servers accessible from one client (device window)
*) improvements for wine
*) bug fixes
v2.0beta7:
*) new builtin function - execute. Allows to make probes and data sources based on
return value or output of exeternal programs
*) new builtin function - device_property. Allows to use device field values in
functions
*) many bug fixes
v2.0beta6
*) new snmp oid chooser control
*) many bug fixes
v2.0beta5:
*) data sources can be fed by functions
*) network map tooltips can evaluate functions
*) crash reporter
*) function probe - probes can containt very complex statements
*) added cpu, memory, virtual memory, disk probes - graphs usage of resources
*) ping function - pings host and returns rtt, size, ttl, error
*) more builtin functions
*) dude database could occasionally get corrupted
*) other bug fixes
v2.0beta4:
*) snmp profiles added
*) discovery uses all snmp profiles to assign proper profile to device
*) snmp version 2c support
*) reworked panel stuff - have separate panel layout for each admin (optionally
for each session), custom panels can be created, panels can be nested
*) panels can be opened in separate window
*) each email notification can specify SMTP server
*) bug fixes
v2.0beta3:
*) bandwidth test tool for routeros devices
*) tools easily accessible from any ip address edit box
*) tools accessible from any lists context menu that has ip or device in
somecolumn
*) files on dude server can be saved on clients computer
*) network map automatic export files are added to dude servers files
*) custom fields for device object
*) expression evaluation, functions - results can be put on network map labels
*) useful functions - cpu_usage, mem_usage, disk_usage
*) chart data can be manually edited
*) status bar shows client and server generated and received traffic
*) greatly reduced server to client traffic
*) many bug fixes
v2.0beta2:
*) automatic map export leaked memory a lot
*) dude uses default web browser to open web links
*) big wireless registration table for routeros devices
*) routeros packages can be disabled/enabled/uninstalled from dude
*) tools can be easily performed on routeros neighbors from context menu
*) open in new window option for submap context menu in network map
*) services can be ‘unacked’
*) default zoom setting for network maps
*) submap links offer all contained devices
*) services show correct uptime/downtime
*) configuration export could crash dude client
*) fixed memory leaks, permission problems in web interface
*) passwords cannot be cheated from web interface
*) many other bug fixes
