The DUDE version 7 question
I have upgraded to version 7 on Dude server. I have a directly connected p.c. that is able to access fine. I have another p.c that uses remote connection, works fine. I have device on the network(mikrotik client) same IP block as The Dude server and when it connects to Dude it says(getting stuff) it will shoot up to about 230k, fluctuates a little and then eventually zero’s out. Has anyone seen this. I haven’t limited connections to my dude server. The server only runs as service on remote devices.
I have exactly same problem, but with V2.0.
Just one machine can’t see data (but connects) like it’s described above.
Anyone else?
Change the NIC or turn off “Checksum offloading”.
That helped my problem.
yeah, so how do you turn off checksum offloading?
It’s done in the NIC config. Should be a checkbox, otherwise Google helps for your specific hardware. :slight_smile:
